over 5 years ago by Martina
Is there a way to fix that problem without having to redo all the walls? I tried to see if I can turn on control points and try something with them but they don't even show..What kind of geometry are the walls we created after commands we used ( curve boolean and extrude curve)?
Hi Martina,
The walls are polysurfaces (a collection of surfaces grouped together). They don't have the options to adjust control points like with surfaces, but you can adjust the corner points using this command "SolidPtOn" (use f11 to turn them off again). It's this button on the toolbar 'Solid Tools'
