Hi Peeter,
There are various ways, I'm not sure what the quickest way is. What is pretty fast is hold your Ctrl-key (a minus appears next to your cursor) and disconnect your wire the same way you normally would when connecting a wire to a component.
You could also Right-click a component > Disconnect > and select the component you want to deselect.
