over 10 years ago by Marchitect
The Curve Boolean command is/was new to me. I wish there was a little more explanation on how to properly get this to work. It took me some trial and error but i think I figured it out. In order for the Curve Boolean to work, EVERY wall, and wall segment must be a closed shape. And very important! When you are using the Curve Boolean command, all the new shapes you are making will go on the current/active layer (Secondary Walls). So, initial wall line work goes on the temp layer, and the Curve Boolean command MUST be on Secondary Walls layer as the Curve Boolean command makes the final wall line work on that layer. This is probably explained in the video, but he goes rather fast. And if your technique is slightly different than shown you can run into problems.
Leika about 10 years ago
Arie Willem de Jongh over 10 years ago
