over 7 years ago by Thomas J. Jensen
Samuel - I am currently enrolled in your How to Create a Revit Plug-in with Python. I am up to part 5 on your training videos. However, after I created the folders - retail automation.extension retail automation.tab retail automation.panel retail automation.pulldown retail automation.pushbutton I do not see an icon file, the retail automation script, the test_scratch script etc. I had been following along smoothly and was able to install Pyrevit with not trouble. But it seems as if you have not provided enough resources for this course. I look forward to hearing from you.
Rodolfo Palma over 7 years ago
Thomas J. Jensen
Hola, Buena tarde.
Soy Rodolfo.
me gustaría saber si lograste solucionar el problema, pues estoy iniciándome en este tema y tengo la misma duda.
me podrías ayudar?
espero te encuentres bien.
Saludos.
Sam Aston over 7 years ago
Hi Thomas, apologies for this process not being clear. We have a course assets file for you to download. Inside of the "Py Exercise Files" folder, are the python files you'd reference or copy/paste.
In the ".pushbutton" folder you created, you are meant to create your own .py script and icon.png. So you'd take one of the Py Exercise files, add "_script" to the end of the one relevant to the lesson you are on, then place it in the folder. Keep in mind you should have only 1 "_script" file per folder. So you'd just add/replace the python code as you proceed through the course with the code from the subsequent Exercise files.
For the icon.png, you can create your own PNG file (keeping it to less than 32x32 pixels, if you can), and add it to the folder as well.
If this is unclear, I can make a video detailing this process and update the course.
Thanks for bringing this issue to our attention!
Pym over 5 years ago
It's unclear to response this tutorial. Can you please a video to help us? Thanks
