almost 8 years ago by Luke Hewitt
The offset direction changed suddenly while following the tutorial from offsetting to the sides of the chosen curves to below them. I have been unsuccessful in redefining the plane to rectify this. Any help is appreciated.
Hi Luke,
Sorry for the late response, could you check if your curve is flat or planar? You can use the SetPt command to Set the Z coordinates of the curve to make sure they're planar.
If this didn't solve the problem, please insert an XY-plane component into the P input from the Offset Curve component. This will force the offset on the XY-plane.
Let me know if this worked,
