over 7 years ago by Rajesh khanna
while working on the diagrid structure and the before vid you used points list component , where it has four options but it shows only two options
Hi Rajesh!
On older version of Grasshopper is used in these videos, in this version the visualize points component had more inputs. Not to worry though, you can still use it like it is used in the videos. Plug in your points in the P and a number for the display size in the S.
