about 8 years ago by Alejandro Pacheco
I would like to find a way to export Revit files maintaining the original colors of the different elements. The purpose of this is, for example, to separate the internal and external faces of external walls (facades) that are shown with different materials in Revit.
Dan Robert Richardson about 8 years ago
Alejandro, I'm guessing, but it may be using a similar technique as the one discussed during 'adjusting .dwg exports' within Revit. I believe that is addressed in Part 1. Essentially, it would different .dwg Layers for each Revit Element. I guess you would use the Pantone xxx-xxx-xxx Color Numbers for each Layer you need to create. Lastly, I am certain this would apply only to Colors and not Materials. Buenos suerte, hermano, I have watched Part 1 twice .... carajo !!!!
