over 8 years ago by MingKeat
Is there anyway to fix the vector of wind load exactly perpendicular to each panel? thank you
Arie Willem de Jongh over 8 years ago
Hi MingKeat!
I believe a windload can only be from one main direction, else it wouldn't make much sense. Let's say you have 100 panels with different orientations and you want to create a windload perpendicular to each panel, you'd have 100 different forces with different directions acting on a panel. You'd be better of calculating the average orientation of all the panels and use that as the wind load direction. Or am I missing something?
