about 1 year ago by Gina Bracho
hello , it seems the revit file asset file is from 2016, meaning is R2016. Can you please update the files so it can be use on more current versions of revit like revit 24 , or 25? every time i tried to open the "04_testproject.rvt file, it crashed, makes me wonder if i am going to have problems with the Dyn files too
Arie Willem de Jongh about 1 year ago
Hi Gina,
Thanks for letting us know. Here is a guide on how to open older files in newer Revit versions: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Backwards-compatibility-of-Revit-with-earlier-releases-of-the-software.html
Just be advised that this upgrade process is not reversible; once upgraded and saved, the file cannot be opened in the older version of Revit.
All the best
