over 7 years ago by XAVIER ALMANZA
how do i draw a curve into a surface like the trim example
Hi Xavier!
There are two methods that will allow you to draw on top of a surface:
The Sketch method is more "sketchy" as the name implies and is more loose and less accurate. The Interpolate on Surface is more accurate as it let's you select the control points which you want your curve to pass through. Try them both and see the difference.
