about 7 years ago by Edmondo Rumori
Hey, is there any difference in choosing between Evaluate Lenght and Evaluate Curve? Thanks
Hi Edmondo!
Good question. The Evaluate Length component is usually used to evaluate a curve at a specific point using a length in meters.
Don't forget to turn the N-input to False. So let's say you want to get a point 5 meters from the start of the curves you use this component.
The Evaluate Curve, however, evaluates a curve at a parameter t. And t is a numeric value that has to lie within the parametric domain of a curve.
Now the domain of a curve and the length of a curve are two different things. It's quite technical but here are some links for you to read up more into it:
https://aws1.discourse-cdn.com/mcneel/original/3X/f/1/f1e548eb7d4f09331d98bbeb351ce453a7f74aa0.png
https://www.grasshopper3d.com/forum/topics/evaluate-curve-at-t?commentId=2985220%3AComment%3A793232
I think the most important difference for me in usage is that I use the evaluate curve in cases where you got a t-value from another component and you want to use it to get a 3d point or the Tangent Vector etc. That's how curves behave with this t-value.
When I want to get a point with a specic length from the start I use the Evaluate Length. Mind you that the L-input is translated to a t-value to get the 3dPoint and the Tangent Vector, it's how curves (and surfaces) for that matter behave. I hope it's a bit more clear
