Hi Tipp!
Good question! This has to do with the orientation of your surface, the U and V are flipped. I believe Rodrigo references a surface from Rhino, here's how to fix it:
1) Select the surface in Rhino;
2) type in _Dir in the command prompt;
3) hit enter;
4) select "SwapUV" from the options in the command prompt;
5) hit enter.
This should do the trick. Now if the surface is generated within Grasshopper. Try this def:
https://mega.nz/#!FBFFFLIA!4jTp9bbFCuXIFm7Mhkdo-Wlt5tOdS4Kq4ceY3LvXxiE
