over 5 years ago by Martina
When I insert the objects they look grey and I have to change to rendered viewport to see their colours. An then I go to properties and change the colour as you showed but nothing happens. They remain as they are.
Hi Martina,
This is because they are block instances. You have to go inside the block to edit the color (use the command BlockEdit).
Also there different shading or visualization modes. The shaded mode (the one from your image) is one way to give color to your objects, another one is Rendered mode. This is the mode is more advanced and you have more options to color your objects or give them a material like wood. glass or concrete. I advise you to watch to Rhino Certification course, where this is explained in more detail.
