over 5 years ago by Martina
Hello. When scaling the image couldn't I just pick as reference points the 0 and 10 meter from the scale bar of the image and then type 10? I tried it and it seems to work. Is there a reason not to do that and prefer the way you are suggesting? Thank you!
Hi Martina,
You're right! I'm a bit OCD when it comes to scaling things to, so drawing a line of 10 meters and using it to scale is how I do it (just to be extra sure).
But you can also do it the way you describe, select a base point for scaling, select the first reference point at the 10-meter mark and then type in 10 and hit enter.
Martina over 5 years ago
Ok! Great! Thank you very much for the response! :)
Martina
