almost 7 years ago by Jeremy Thomas
Hi Arie, Maybe this is a simple question but could you please explain how you've set the sections and elevation drawings relative to the plan? You set the start of the main floor plan at 0,0 but the bottom corners of the sections and elevation are at some other points. Could you tell me where those points are?
Hi Jeremy,
Thanks for your question. I kind of guessed it based on photos, the plans and sections. It's a bit of trial and error and it's not perfect as some are a bit off.
It's manully moving them and seeing where they fit with other sections and the floorplan.manually
xuexiniubofan almost 7 years ago
First, making sure all ref. images are in same scale. Secondly. matching sectional drawing with the floor plan those has same cutting dimension and contents or other related graphic info. hopefully this can answered your question.
